Greetings!
We have a Whirlpool GS6NBEXRL01 refrigerator. It's ~16 years old but still functioning fine. We recently discovered a pinhole in the pex water tube from the water source to the refrigerator. Part number on the tube is 2305520 and in researching, the alternate part number is WPW10296832. I can't find either of these in stock at AppliancePartsPros or anywhere else. I also couldn't find a potential alternate part number that would work.
By chance can anyone help provide an alternate part number for this 16 year old unit? I could try to cut the defective ~1" portion of the tube out and attempt to splice it together, but I'd rather avoid that as this is water.
Thank you in advance
