Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Fridgidaire LFHB2741PF5A that for some reason the ice maker will not quit running unless you open the door. This is a french side by side with water & ice in the door. Everything else works just fine other than non-related front digital display partially gone. Water works, trap door opens and closes when the lever is depressed - the auger just won't quit turning.
As a temporary stop I removed the top panel of the ice maker and un-plugged one of the two available plugs and it is stopped for now
Any ideas on what part or parts I need to fix this?
Thanks in advance for any help
