AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Lg front load washing machine excess drum wobble
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Washer stops mid cycle with error code IE. we changed the door latch, but the problem persists. I noticed today a lot of wobbling vibration when spinning. I steadied the case and it allowed the washer to shift to spin fast enough to finish the cycle. What is the most likely problem: a broken spider, a spring is loose or broken or a problem w the counter weights?
Washer Repair
