harryj
#1 Posted : Saturday, November 7, 2009 10:17:52 AM(UTC)
harryj
Need Help?
I know I need a bake element. I was looking in the back of the oven and disconnected the red and yellow wires to the bake element(bottom) and left them disconnected and plugged in the oven and the red wire was touching the white(neutral ?) of the power cord and I saw a spark. The red wire of the bake element is burned but it still has continuity to the circuit board. I checked with an ohm meter. Now my broil element is out and it was working fine before my mistake. I tried taking off the circuit board to check for a blown fuse but it was too difficult.
I know I need a bake element, but I don't know if I need a broil element as well or a new circuit board and bake element. Do I need all 3? 2 elements and a circuit board?
How do I replace the bottom element? From the back or inside the oven.
Whoever is willing to help, thank you and I may be contacted on my cell at 317 224-9000 or harryjo00@hotmail.com.
#2 Posted : Saturday, November 7, 2009 2:39:06 PM(UTC)
Quote:
...the red wire was touching the white(neutral ?) of the power cord and I saw a spark...
Sounds like this short caused damage to the control board. So you probably need a new control board and bake element.
In order to access the Bake element you have to remove the oven floor.
- The control board (aka a clock/timer) Part number: AP4100740
- The Bake element Part number: AP4101290
harryj
#3 Posted : Saturday, November 7, 2009 3:35:13 PM(UTC)
harryj
I appreciate the help. I didn't want to replace the clock/timer since it's the most expensive part but don't have a choice now.
Thanks,
Harry
harryj
#4 Posted : Sunday, November 8, 2009 6:57:55 AM(UTC)
harryj
When you said the bottom, did you mean turn the oven on it's side and work from the bottom of the oven or inside the oven? I can't see how I would take it out from the botom. Is there a video out there on the web anywhere on this?
