Joined: 1/16/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
Hello, I have a 2006 SHE66C05UC dishwasher. It will pretend to go through its cycle and say 20 minutes into the cycle, I can open the door and all will be dry and there will be hot water pooled at the bottom, as the minute timer counts down.
I replaced the circulation pump, did not fix. Then, I found out about diagnostic mode, it shows code E01. I replaced the Thermister, did not fix.
There is a slight burning smell when attempting to run.
Anyone know?? Thank you!
