Guest
#1 Posted : Wednesday, January 12, 2022 5:18:28 AM(UTC)
Guest
Rank: Guest
United States
Model Number: ETW4400WQ1 top load
Brand: Whirlpool
Age: More than 10 years
I have repaired this machine many times even as far as rebuilding the transmission. The current problem is that on the agitate cycle, the bottom agitator rotates only anticlockwise, and when it should reverse it just gives a scraping snarl
Everything's else seems to work fine. Can you suggest what it might be?
Michael
ThatGuy
#2 Posted : Wednesday, January 12, 2022 7:27:43 PM(UTC)
ThatGuy
Groups: Expert
United States
Its inside the transmission.
https://www.appliancepar...n-3360629-ap3096209.html
Something is damaged or just worn out. You'll need to disassemble it, but finding parts is hard.
Guest
#3 Posted : Sunday, January 16, 2022 5:07:27 AM(UTC)
Guest
Rank: Guest
United States
Thanks for your reply. Actually I recently rebuilt with a new neutral drain kit and a new gear rack (which had cracked). I was careful to reassemble correctly.
ThatGuy
#4 Posted : Sunday, January 16, 2022 9:19:39 AM(UTC)
ThatGuy
Groups: Expert
United States
Guest (4)
