wpollock
#1 Posted : 3 years ago
wpollock
Want to change factory bulb, halogen type G8 ( Bi-Pin), 130 volt, 50 watt 210515, with equivalent LED. So far unable to find exact LED match. Any replies are appreciated.
wpollock
#2 Posted : 3 years ago
wpollock
So I ended up replacing the halogen type G8 ( Bi-Pin), 130 volt, 50 watt 210515 bulb with DiCUNO G8 Dimmable LED Bulb Flat Base 4W (40W Halogen Equivalent), Daylight White 5000K, 450LM, Bi Pin Base Bulb Replacement for Under Counter, Under-Cabinet Light and Puck Light, 6 Pack and found on Amazon. Early on after the change but no issues so far. If nothing else, the color of the light seems to make food being cooked easier to see.
