Joined: 1/7/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: MS
For about a month now, my whirlpool refrigerator/freezer has worked on and off, but it won't maintain the proper temperature. The coils are not frozen over. Using the refrigerator temperature dial, I can force the compressor to come on. By doing that, temperature on both sides (side by side) will go down. However, the temperature does not hold on either side.
How can I troubleshoot this? Could it be the defrost thermostat? How can it test it while in place?
Thank you!
Joined: 3/30/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 1085 Business Lane, Suite 9
I encountered a similar problem with my refrigerator and repaired it from the mechanic’s shop. They explained to me, that condenser coils dispel heat as the refrigerant passes through them. And if you see the coils are clogged in dirt and debris, it can’t release the heat properly and the cooling doesn’t happen.
