Hello, I appreciate any assistance that I can get! This is a slide in gas range that is perfect for my kitchen! I'm about to list my house for sale and I need this range working quickly!! (1) One knob, front left, will not activate ignitors. How do I test if problem is the knob switch harness? (2) Oven ignitor does not work. How to test if it's just the ignitor needing replacing? (3) Back left top ignitor does not ever spark. How to test if it's bad? (4) Two top ignitors spark but often arc to the side rather than upwards, rarely do they ignite. What is the problem? Everything is clear on those parts so cleaning them again will not make them any cleaner. (5) One top ignitor sparks when it's supposed to but it misses igniting the gas way to much. I have used a lighter to ignite the gas on the top burners. They seem to work/burn just as good as my old range used to - good flame and all that.
Thank you for your time and assistance! Lloyd
