SO! Last night I deep cleaned the stove. I didn't dowse it with water but i scrubbed the inside on the range. After, the burners wouldn't spark. I decided to remove the center panel that contains all the wire. After i shifted that the ignitors started sparking and wont stop unless the stove is unplugged.
What do you think i shifted in the box to make that happen?
Thanks for your help!
