Hey all, my KitchenAid fridge (KRMF706ESS) has been making this intermittent knocking/pumping noise every so often (couple times a day) and will last anywhere from 5-20 mins. When the sound is happening, I can't dispense water. Wasn't sure how to upload audio, but I linked it here: https://file.io/LmUe6o9ETh8ZNot sure if it's coincidental, but about a month or two ago, the cooling went out everywhere... had to power cycle and pull it out and cleaned up the dust. It has been fine ever since. Any help would be appreciated!
Originally Posted by: bldrco  Hey all, my KitchenAid fridge (KRMF706ESS) has been making this intermittent knocking/pumping noise every so often (couple times a day) and will last anywhere from 5-20 mins. When the sound is happening, I can't dispense water. Wasn't sure how to upload audio, but I linked it here: https://file.io/LmUe6o9ETh8ZNot sure if it's coincidental, but about a month or two ago, the cooling went out everywhere... had to power cycle and pull it out and cleaned up the dust. It has been fine ever since. Any help would be appreciated! does is the ice maker cycling?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: cfaber  Originally Posted by: bldrco  Hey all, my KitchenAid fridge (KRMF706ESS) has been making this intermittent knocking/pumping noise every so often (couple times a day) and will last anywhere from 5-20 mins. When the sound is happening, I can't dispense water. Wasn't sure how to upload audio, but I linked it here: https://file.io/LmUe6o9ETh8ZNot sure if it's coincidental, but about a month or two ago, the cooling went out everywhere... had to power cycle and pull it out and cleaned up the dust. It has been fine ever since. Any help would be appreciated! does is the ice maker cycling? Ice maker is making ice!
