Blacksuit
#1 Posted : Sunday, December 12, 2021 9:10:30 PM(UTC)
Blacksuit
United States
I have a frigidaire FFHA2622msva that I just replaced the auger but I put the blades in backwards so it was not dispensing ice. I took the ice bin out and put in the ice blades correctly, I checked the actuator rod to make sure the flap for the ice chute was opening when moving it.
After I replaced the ice bin and pressed on the button to dispense ice the flap was not opening. It was prior to me realigning the ice blades. I noticed that the actuator rod was not being pushed up when pressing the ice dispenser on the door. I dont know if that would be considered the actuator solenoid behind the cover or not. Any ideas and how to test if it is the solenoid?
Thanks!
