Hey Everyone, My dual element inside isn't working, but the outer part is. The red light comes on for the outer part, but doesn't for the inner. Does that mean it is my switch or the element?
Thank you so much for any input!
It turned out to be the switch. I swapped the working one for the faulty one to determine if it could be the switch. The two dual burners swapped the problem. Thank you!
