Joined: 12/8/2021(UTC) Posts: 0  Location: Washington
FGHC2331PFAA
My freezer isn't quite freezing to 0
I've cleaned the coils.
The top of the freezer door extends nearly 1/2 inch beyond alignment with the refigerator door. The seal is making contact, but I suspect air is leaking in.
The bottom is correct.
Before I take the top hinge apart, is my problem correctable at the hinge?
Is there a diagram of that area available?
