Hi, I had a self-cleaning cycle issue (blown fuse). I have replaced the fuse, which brought the oven back to life, but both my wife and I are noticing some weird behavior: - It takes it longer to preheat
- Once in a while it just will get stuck in Preheating mode, 30-40 degrees under desired temp. Switching to “convect bake” for preheating seems to solve it
- It also seems like it doesn’t hold the desired temperature well (goes down 40-50 degrees from the target temp), but I’m not sure how to test that
Are there other parts I should have replaced after a self clean? Any other ideas of what could be wrong here? Thank you
