azurebat
#1 Posted : Monday, November 29, 2021 2:45:31 PM(UTC)
azurebat
Came back from a weekend out of town and no water to icemaker or dispenser.
I checked the inlet at rear bottom and disconnected fridge side hose, press dispenser and water comes out of valve,
Ice auger works and solenoid in bottom of door appears to work. No water to small tank in door. Feed from that tank goes to that valve in the door so not that. Pink wire to board has voltage.
Replaced water filter with bypass.
No change
Scratching head
