My fridge is only a bit over 3 years, my top compartment is warm, not getting any cold/cooling air in, my freezer compartment is working, it's cold as usual or as a preset (0 deg. Fah, my fridge is set at 37 deg. Fah)
Any ideas?
Thank you in advance for your help!
I have a similar issue. The freezer circulation fan stops after awhile or doesn't start at all. Check yours. I have a french door and the only internal fan is the one in the freezer which feeds cold ir in the refrigerator controlled by a flap door.
I am just starting to work on it.
