Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Our dishwasher won't start and the clean light flashes. I tried the reset procedure but it didn't solve the problem. The LEDS of the control panel buttons work, but the only button that functions is the cancel button, which when pushed by itself (no other button pushed) it causes the pump to run even though the unit is dry. There were no issues with the unit until this happened. Research suggests that it may be the heating element or fuse, but it seems that it may be the control panel? Any suggestions? Thanks,
