Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Whirlpool Duet electric dryer model no. GE9200LW1... The dryer makes a loud squeal trying to turn the Drum... The Drum spins under a light load and but will not spin with a heavy load, it just squeals loudly. Is this a belt or could it be a belt and does the dryer have a tensioner pulley, that may have failed? Do I need both? Does it have both a tensioner pully and belt? The dryer is over 10yrs old and everything worked fine until it started having trouble spinning. Edited by user Wednesday, November 17, 2021 7:04:17 PM(UTC)
| Reason: typeograohical errors
