AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Kenmore Elite 795-72482.210 freezer and refrigerator are not making enough cold
Please help. Freezer items started thawing and ice packs that used to be frozen are now soft. Refrigerator temp rose to 12 C or 52F. Cleaned dust from condenser coils. When the fridge starts, the compressor starts, hums, and appears to work. Checked the evaporator coils for ice build-up - there was no ice. The defrost line is not clogged, Both the condenser and evaporator fans are working fine. No coolant leaks. So, if the condenser and its fan are working, the evaporator coils are not frozen over, the drain line is not clogged, the coolant pressure is normal, the evaporator fan is working, now what? What else can I test to narrow it down? Model Number 795.72482.410
Thank you all. Edited by user Saturday, November 6, 2021 8:02:15 AM(UTC)
| Reason: Not specified
