I have a Jennaire question or possible issue with Jennaire JGS8860BDP oven door. I had the electric button panel replaced (because some buttons started failing) and the oven door gray insulating lining stuff around the door replaced. Previously, the buttons were failing. I notice the door is not 100% flush when closed, a gap is visible towards the top of the door when viewing from the side. Is this a possible issue, or cause of why my control panel had failed? Thanks. Looking for inputs and opinions.
