Joined: 10/28/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
My Frigidaire gallery FGID2466QF2A from 2014 refuses to start. The front led work fine. The start button works, but when I close the door, nothing happens.
The door latch tested good for continuity.
When I power cycle, PF appears, and I can hear the circulation pump quickly spin for 1 second if the door is closed. If the door is open, I do not hear the pump.
I took apart the circulation pump to clean out the debris.
When in PF mode, I enter service mode, the led says CL, regardless if the door is open or shut.
Anyone have any clue?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
I am not familiar with your dishwasher, but I did a search for error CL and found this...
"The CL. code is a clean sensing indicator given from the optical water sensor. If it gets dirty or failed it emits the code to the board. It insets into the lower wash sump area and is accessed from the bottom. Part # 154473901. You also need to make sure your incoming water temperature is at least 120°, if not then turn up the water heater. Use dishwasher magic monthly so you keep the unit clean and working up to performance level efficiencies."
Also there was a lot of talk about a burnt resistor on the main board causing the CL error. I hope that helps.
