Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Dyer blows fuses in panel box as soon as it is plugged in. Where should I look for shortage. Worked fine then blew a fuse. Changed a thermostat but tester showed it as fine. Heating coil tests fine
