jensenpe
#1 Posted : Monday, October 11, 2021 7:28:24 AM(UTC)
jensenpe
This front load washer runs fine 90% of the time but occasionally will stop mid cycle with the drum full of water during the wash cycle. Coaxing the washer to run involves shutting off the washer and rotating the drum a bit, closing the door and starting it t the exact same spot on the timer. It occurs at the exact same spot on the timer so I replaced the timer but the random problem continues.
Ideas/suggestions?
Thanks.
