Hello,
I have a Samsung RF267ABRS refrigerator that the water dispenser quit working over night. When I started with the water inlet valve but that is not the problem. Because I am able to get ice by pressing my glass against the dispenser switch I assume the dispenser switch is not the problem. Because everything else other the water dispenser works at the dispenser I assume the water filter is not the problem. When I open the door the light comes on and if the door is left open the alarm will sound so I assume the problem is not with the door switch. The dispenser control board will go into all its modes so I am not sure its the problem. That just leaves the waterline that is either stopped up with ice or mineral deposits. How do I go about addressing that? Can I blow it out with an air compressor or fine wire of some type?
Sincerely,
