I installed a new Inlet valve to fix a noisy inlet value problem
I now a different problem… When I went to test run the appliance the whining had stopped, but the dishwasher had trouble maintaining the cycle….it would fill okay, but then quit about 60 seconds into the wash cycle then start to drain and then shut off.
After using the cancel & drain function a couple of time I finally got it to complete a full cycle, and I thought that it was all okay.
Nope….last night after dinner it quit again 60 seconds into the wash cycle. Despite repeated attempts to clear/drain and retry the wash cycle it would not complete the full cycle. It gets about 60 second in and then starts to drain.
Any ideas anyone??? Model number KUDC10FXSS5
Andrew
