my dishwasher will fill up with hot water, then instead of moving to a wash cycle, it drains the water back out. then it just hummms. it's not going thru the wash or rince cycles. It does not matter which cycle i start with i tried pot&pans , just rinse , or normal wash. none of these cycles work. it just fills then empties....can you help?? It is a Maytag model # MDC4809PAW1
