Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
LG front load washer is making a grinding noise when drum goes to spin. Make its when going clockwise, counter clockwise runs fine. Rotor was not loose at all when i removed the back panel. Took the rotor off and no wear to the gear part and no cracks in the metal magnets. Someone please help, I have a video with sounds but does not look like I can post it here
