Hello,
I have searched the old questions and can't find the exact one I have. I have an older KitchenAid Wine Chiller that has stopped cooling. Both fans and the condenser are running when turned on and turn off and on using the thermostat knob. I have replaced the thermostat once before with a part from here and help from this blog.
My question is. Could the defrost timer be out or is it more likely an problem with the sealed system? I don't mind buying one and trying before trashing this expensive unit.
Thanks for any help.
