AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
LG LDT5665BD Error 1E - could it be flow sensor or PCB?
Hello, So here’s what happens - start a new cycle, no fill, no solenoid movement on detergent, and then after about 3 minutes, error E1 shows on the display. I’ve checked the door latch sensors, both have continuity. I checked the blower parts, no issues. I checked the inlet valve by applying 12vdc and the solenoid activated with no problems. The diagnostic tests failed on the solenoid for the detergent, fan was ok, soil sensor was ok, outlet pump was ok, inlet valve failed, the other two tests seemed to be ok, but obviously no water in the washer. any advice on next steps?
Dishwasher Repair
