Recently my whirlpool GS440LEMT2 oven started making noises and displaying the E0 F2 error on the control board. After doing some research I was able to find the stickied topic for code EO -F2- and followed the instructions there with no luck. In short I removed the control board from the oven, removed the ribbon cable, cleaned it, reattached the ribbon to the control board and then plugged the power cable back into the wall. At this point I'm not entirely sure if I need to order another control board or try something else. Any help would be appreciated and thanks in advance. Edited by user Thursday, August 26, 2021 4:30:31 AM(UTC)
| Reason: Not specified
