AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Bosch SPV66TX01E/01 continuously beeping OR not draining
Hi everyone,
I have an issue with a Bosch SPV66TX01E/01 washing machine. It started when it wouldn't drain, I cleaned the filter, I checked the opening for the pomp, i didn't see anything suspect, the little propeller spins freely. Then it worked once or twice, then it didn't drain again. Cleaned again started and after two minutes or so it started to beep continuously and won't stop until i open the door. If the door is closed back it starts beeping again. Then I reset it, it works around 15 20 mins into the cycle and stops with an exclamation mark on the floor and 00:00 (no error code anywhere). I stop it, do the reset (00:01), restart, it drains the waters, it starts and beeps again continuously ... and this is a never ending loop ... Can someone please help us with some tips?
Thanks in advance! Ovi
Dishwasher Repair
