Joined: 8/10/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
If I start a load in normal cycle the timer continues to run and goes right into extra rinse even if not set. Then if left will continue into the next cycle on the timer. I have to unplug the washer to get the timer to stop running.
