Damien8
#1 Posted : Monday, August 9, 2021 7:25:10 AM(UTC)
Damien8
Canada
About a month ago, I spilled a significant amount of water on the stove top, and it ran down into the front mounted panel. I saw the display flicker, and then eventually, turn off.
I unplugged the unit as quickly as I could, took the display out, and put it in a big bag with rice to dry out. I reinstalled the next day, and it worked perfectly.
Fast forward to yesterday, and now the panel is blank. When I press the buttons, it beeps and seems to work (for example, over light will turn on, and over itself will start up) but I can't see what I am turning on because the display is completely blank.
Is it likely that I friend the display board, or could is there a chance this can be fixed?
Any help would be appreciated.
Thank you!
