Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello,
The water dispenser has begun to randomly dispense water on it's own.
I've replaced the micro switch part #6600JB3001C, which appears to be for the ice dispenser. Unfortunately, this did not fix the problem
I've also purchased an additional micro switch part #6600JB3001F, for the water dispenser. I was under the impression that our fridge has 2 switches, however, I'm unable to locate this one on the parts diagrams.
Does this model have 2 switches and if so, where can I locate the 3001F switch?
If there's only 1 switch, what should my next step in diagnosing the problem be?
I'm hoping it's not the dispenser control panel.
I appreciate any help/guidance you can offer.
Shane
