Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I had an issue with a loud grinding sound at first like a motor tub coupling so I replaced it with no luck. Still same issue but sounded like a bad bearing so changed the gear box with a new one while I had it apart i also changed the splutch in the process of changing the splutch gear the new one was very tight on the spindle and would not spring at all so I used the old one with the new spring, the splines on the old gear looked fine, I did use the new pulley it came with and belt but the old one did not look worn down at all. When I recalibrated the washer and tried to test wash afterwards it barley spins it stops and flashes at rinse. Any advice would be much appreciated its driving me crazy! I posted a video below on the current sound I'm getting. Model Number- MVWX655DW1
