AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore 400 washer fills and agitates the entire cycle
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Washer just started getting stuck on the fill and agitation through the entire cycle. When you open the washer at the end of the cycle it's full of soapy water. I believe it's the timer since when i advance manually to drain it or spin it works. Also if i am on the spin cycle and open and close the lid the spin starts and stops so dont think it's the lid switch. your thoughts?
Washer Repair
