Model KRSA25ILSS01 Make KitchenAid
Last week I noticed the water would initially come out at a normal flow and then within a second quickly slow down to a dribble. It was so slow the ice maker would not work as the tray would not fill up.
I don’t have a water filter - have not had one in for over a year with no issues.
Initially, I thought it would be the Water Valve so I replaced that with no luck.
Any thoughts would be sincerely appreciated.
Pj
Groups: Expert
What you are describing is water pressure, but no volume. You need to check the water line and shut off. Maybe a kink in the line or blockage in the shut off.
