Guest
#1 Posted : Sunday, July 4, 2021 12:16:28 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
My Maytag Bravos was making a lot of noise on spin, so I changed the bearings. It worked find for about a week, but then I got an F 51 error code. I have checked the rotor bolt and cleaned the rotor sensor, but no help. When I changed the bearings, I found that there is water trapped in the drum/basket. Could the trapped water be my F 51 problem? I don't see how because it was there with the bad bearings and I got no error codes? Anything else that I might try?
Thanks for any suggestions! I am at my wits end.
