Guest
#1 Posted : Saturday, June 26, 2021 8:04:08 AM(UTC)
Guest
Rank: Guest
United States
Hi all.
I have the above dryer and everything works fine with the exception of not heating. This is a new problem... not something that has deteriorated over time.
I've tried to do a little research and found the items below are often the problems.
Heating Element
Thermal Fuse
Thermostat
Looking for a service manual if someone has a PDF and is willing to share. Also looking for advice from someone with experience to let me know if there are other parts I'm not thinking of that I should look at.
Thanks in advance!
