Rank:: Member
Hello,
I’m hoping someone can help me find the right part. My refrigerator is GE (Model - TRX22PPDABS, Serial TZ291699).
For the last few weeks I have noticed frozen water at the bottom of the freezer door. Today that ice is now water and it sounds like the compressor wont start. I can hear clicks from the compressor from trying to start every few minutes but it wont turn on. I have cleaned out the condenser coils, fan, and everything around the compressor. The previous owners of this house had replaced the defrost heater twice in last 10 years.
So far I have tested the following with these results:
Start Relay (part WR07X10099) With Ohms being set to the 200 level it reads with a continuity beep and 8.9 OHMS ( I believe this is only supposed to be about 5 Ohms)
Overload for the relay: tested set to 200 Ohm level reads with continuity beep and 0.3 Ohms
Defrost Heater “part WR51X10101” is a double element and one side is jumpered between the two elements. When I read the ohms at the “200” setting between the blue and pink terminals (one for each element) it reads 26 ohms. When I remove the jumper between the elements and test the terminals at each end of a single element, the reading is 14.1 Ohms.
I am hoping you could tell me if the readings I have are normal for these parts. If not, I would definitely like to place an order
Thank you for any and all help
