Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Older GE oven bottom element.
Model JBP26G S2WH
Serial TL231811G
Called GE parts - told me part number is WB44X5082 and updated model number for oven is just JBP26G no extra characters.
Here's the deal. Could barely reach or see what I was doing removing what was left of the old broken-off bottom element. Finally got the first 2 screws out, then pulled it out, got the second 2 screws out and wires that were on there flew back into the cavity behind the oven. Now I have 1 yellow wire and 1 black wire. But in my searches online for videos and instructions, seems like most of these things have TWO black wires. So I don't want to have to deal with the nightmare of pulling the whole oven away from the wall then dismantling the back in search for a second black wire - if it doesn't exist and all I have is one black wire. I am assuming whether or not there are 2 or 1, they go on the left connection and the yellow goes on the right?
Any advice or suggestions would be greatly appreciated. Thanks.
