Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hi there, I have a Whirlpool range YGFE461LVS0. When I choose the bake function, it won't heat anymore. I measured the resistance of the heating element: 17 ohms; the thermal fuse is a few ohms. Both seems working. When I disconnect the 2 terminals of the heating element, start the Bake function, the AC voltage between the 2 terminals of the cable that is connected to the heating element: 120V. Any ideas, which part needs to be replaced? Thank you very much in advance.
