Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello
I have a 18 month old Whirlpool WRB322DMNV01 which has stopped running. The lights turn on if you open the fridge or freezer door. The digital readout of the freezer and fridge are " -" if i press the up or down for either the dash stays there. I unplugged over night and still the same, no compressor no fan.
The start cap on the compressor is 11.8uF should be ok. On the compressor I measure 6 ohms on one side and 7 ohms on the other.
Is there a way to test the control board to see if it is broken?
Thanks Jason
