Joined: 4/26/2021(UTC) Posts: 0 Location: Orlando, FL
Continued problem of the new icemaker icing on the back side. Hard block ice it seems. I'm assuming the water tube is either leaking or splashing and running down the back of icemaker. I purchased a new icemaker from AppliancePartsPros but have the same issue with the new one. It works for a couple months and then stops dispensing ice. It makes ice okay but wont dispense after a few months...assumption is that after the back freezes solid it stops dispensing.
