No lights showing on control panel of GDT535PSJ2SS Dishwasher 5 years old. Pulled kick plate and has good power and connections. Motherboard showed a solid green light - interpreted it as bad motherboard for software failure. Ordered new board from AppliancePartsPros and when i went to install, it says to set the "personality jumpers" for your model, but no instructions included with part, and there aren't even jumpers in that area of the board. There are solder points where there could be one, but was made without one. So very confused on how to setup / install as it still is not communicating with the control panel.
