AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
FDB750RCC2 Thermostat and Heating Element Connectors
Joined: 3/26/2021(UTC) Posts: 0  Location: Los Angeles
Frigidaire / Electrolux FDB750RCC2 will not heat water, nor heat dry. When checking the Thermostat, saw the connector from Thermostat to Heating Element is detached. And one of the Heating Element nut / insulators is fried or disintegrated. Wondering if I can swap out the heating element, the nuts, and the Thermostat wire / connector. Element is easy to find in part listings. The wires and leads and connectors, not so much. Thanks.
Dryer Repair
