Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
So it’s a brand new dishwasher. I cut it on the water comes in I hear it fill it starts pouring out of the top arm and I keep hearing a clicking sound every 15 seconds or so but it never goes into wash cycle. It’ll fill again then I hear a click, then it starts filling again then I hear a click. I replaced the circ pump and it’s still doing the same thing. I noticed that when I opened it up from the interior to check the impeller there was two check balls in the same spot? In the parts manual I only see one check ball? Is it possible that an extra was given? I’m going back to the house in the morning to take one out and see if it still does the same thing? But my next guess would be the float sensor or inlet valve but I’m a homeowner I’m not a repair guy and I don’t have the money to pay someone to come out and try and fix it. Any help would be great thanks in advance. Again the unit is brand new from the store. However it was an open box so I got it at half off which voided the warranty. Otherwise I would’ve returned it.
