AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
help with samsung dryer not heating : DV350AEW / XAA
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello. This guy isn't heating. I checked all the parts on the heating tube and the thermistor. I think I found this issue but want another opinion :) I think the problem is the relay in this picture. https://imgur.com/a/9tftD2JThe relay part is Tyco T9AS1D22-12 When the dryer is on, there isn't continuity across the two contacts on this relay which from my poking around inside seems to power the heating coil. What do you think? I can't find the main board online anywhere to buy. From my research its : ASSY PCB MAIN DC92-00382A. I'm thinking I need to try and purchase the relay and try and re-soldier a new one. Ideas? Thanks!
Dryer Repair
