Can't get the top off the Dryer to check the belt
to lift the cabinet push on sspring catches (2) with a putty knife on each side on the older model. The newer modle you will slide top forward and lift up. Some GE models have screws joining cabinet panel to cabinet top. Open the door to look for screws
